- Aug 11, 2007
- Stevens Point, WI
it is kind of odd about these motors filling #6 first.i got to looking and only #4(pass. front) isen't bent at all.1,2,and 5 are about 1/16-1/8" low.hell it turns over good now without the piston and rod,maybe i should pull the #6 pushrods and put it back together
evan were you using the factory intake in the grill when you got swamped?what have you guys come up with to avoid using that drinking straw ford calls a cold air duct?i was thinking i'de keep mine and put a slider where it goes to the air box.then run a duct to the cowl with a slider there also,so i can chose where my air is coming from.
At the time it was hydrolocked it had the stock intake thru the front grill. Now I have a duct fabbed up that draws air through the wiper cowl. Additionally I try not to drive through excessively deep water, and if I do I go easy on the engine so I don't get caught at 4 grand if water gets in.
