grumpynuts
- Apr 11, 2011
- Automatic
ello everyone. I have read this forum extensively over the last couple of weeks and found some good advice. But alas, I am at an impasse.
2001 ford ranger 3.0 non flex fuel, automatic, extended cab, vin code u,
approx. 125k on the odometer. Car running rough, never had a plug and
wire as far as i knew, replaced the plug/wire and worked a little carb
cleaner in through the throttle, cleared the misfire code, and replaced
the fuel filter. Comes back a few months later, hard start, rough idle
yet still drivable quickly went to no start and would not hold idle,
with backfire through the intake, visualized with intake tube off. Code
comes in misfire. Coilpack check came back bad firing on cylinders 5/6
and R/R. R/R (remove and replace) timing chain, with full chem soak of
intake manifold, superficial cleaning of injectors. Timing chain set to
6 and 12 o clock on the marks cam and crank respectively, piston 1 on
TDC on intake stroke. Put back together, new gaskets, with marked vacuum
lines and attempted to start. Battery failure and subsequent R/R. PCM
failing to communicate intermittently, then full failure, R/R with one
off of a 03 same spec junker, reprogrammed the PATS system. Still no
start, followed up with alternator and starter test, starter solenoid
fine, mechanically failed due to bad journal bearing. R/R starter,
reinstalled the alternator, still no start. Fuel pressure check revealed
bad check valve, replaced the fuel pump as it is part of the assembly.
R/R fuel pressure regulator due to fuel in the vacuum line. Managed to
get it to start a couple of times since, will die on idle, but will hold
throttle. Minor noise from the lifters, would subside after a few
seconds, possibly dry due to extended downtime of the motor. Rechecked
vacuum connections, and attempted leak check with carb cleaner when
running with no drop in rpm. Superficial smoking from the top of motor,
possibly due to cleaning agents on surface, fuel level is fine and oil
pressure/level fine. Initial starts will result in very pungent white
smoke out of exhaust, similar to a running fuel injection cleaning,
possibly due to residue from manifold cleaning, will clear up within a
minute. IAV at 10 ohms and reasonably clean. DPFE was out of spec on ohms, replaced, nothing either. I cannot think of anything else at this time. Honestly I don't
know how this truck ran before. I know this is long, but welcome to my hell. Thank you again.
