Cranked
polkat
northern Wisconsin
okay they are cranked but one side the bolt is almost bottomed out and the other side is about 1/4" + threads to bottom hope that this is okay I measured from the bottom middle of fender to ground I wanted to make it match the rear it does now one side is 1/8 higher that the other I left it and recheck tommrow. I didnt notice the tires going down though when I dropped he jack thats when I noticed the change. now i have to convince the wife that I need tires:icon_hornsup:
It is normal that both bolts will be at a different position, just make sure sure both sides are the same height and you're good to go...
