Crank no start fuel pump?
Johnnyboiranger22
St Petersburg, FL
2.3 (4 Cylinder)
Hey guys. Got my engine and trans all bolted together and all parts put together. But I'm experiencing issue with crank truck will crank but does not start. I thought timing may be off but i never messed with the timing. Checked to mack sure everything was plugged and i have spark which it seems i do. Got code 95 -Fuel pump secondary circuit failure so I went straight to fuel Since I had just swaped the fuel filter I pulled fuel lines and no fuel whats so ever came out . So I check Inertia switch and even fuel pump relay which all seems to be good. Yanked my bed off to get to fuel pump and unplugged line and lord behold still no fuel came out. So yanked fuel pump and found this... Fuel pump completely rusted pump line in corroded from inside i believe. Its hard to believe as i just replaced this fuel pump not even a year ago. Anyone ever seen this?
Aint ethanol awesome....
