Crank no start 93 4.0l 4x4
Forgot to look at it yesterday so I'll check it out tomorrow and get back to u
Failed again I promise I'll order the pcv tomorrow and see if that helps
@93ranger4.0l , since it starts on starter fluid, 35 psi on the fuel rail is too low for the 4.0l OHV:
• check for leaks
• fuel pressure regulator
• injectors
K weres the regulator 2 i think it's a leaky injector
Regulator is on the fuel rail.
Is it under the throttle body
IIRC on the driver's side near the back. Between the upper and lower intake.
It'll look like this:
The threaded part will have the fuel line on it. The o-ring part goes into the fuel rail, and the smaller fitting has vacuum.
Often when they go bad they'll leak fuel into the intake via the vacuum line. A leaking fuel injector would leak fuel into the intake on that cylinder. Pretty similar symptoms.
Event Coverage
TRS Merch
