JDanger
- Mar 28, 2009
- Automatic
I am new to the forum as I just bought a 2003 Ranger FX4. It has the typical sag in the front and I want to level it up. I did a search but didn't really find an answer to my question. I have been told by several people that using the keys is better than cranking the t-bars. One reason mentioned was the ride quality will be less affected by using the keys vs cranking.
Also, I may have screwed up. I measured from the ground to the fenderwell on both sides of the front and the drivers side was lower so I cranked it up to level it from side to side and then cranked both sides up to raise the front. It didn't give me much lift at all and the drivers side bottomed out. I backed both sides down just a touch but it still sags. Have I screwed up the alignment and if so is there a way to zero both sides and start over? Thanks
