Coyote swap
Jongeezee
Alaska
New to posting but read a lot on TRS. Need some help! I need a list of everything I would need to do an engine swap in a 94 B4000. I would love to cram a coyote under the hood, and a F150 digi dash setup in the cab.
Current setup, 94 Mazda B4000, 3" body lift, 2" leveling kit, pacer performance headers, gibson muffler, E3 plugs and wires, K&N air filter, etc.. on 35x12.5 bfg mud terrains
List;
1. Everything
ok, seriously, you’ll need engine, transmission, transfer case if 4x4, engine/transmission/transfer case wiring harness, ecu, instrument cluster, probably all instrument cluster related wiring, might have to build custom engine mounts, steering might be in the way and need modification. I would probably recommend the coyote radiator and trans cooler. I would assume the coyote vehicle has some kind of security (PATS?), so you will have to deal with that.
There’s a rough list. Gonna be a bunch of work. But fun when you get it finished.
