country0001's Blue B2 build
Lift in, gotta take it in to get aligned this week.
What brake lines has every one used with a 4" lift?
I'll research that later today.
i think for brake lines there is a artical in the tech library about pieceing two hose's together
:worthless:
Thanks already found it. Got em on and drove it all weekend. Very happy with the results. Haven't taken any pics yet. Still have to hook up my t case shifter.
Is the 1350m shifter different from the 1354m shifter?
Lift installed, 1354m and D35 installed.
Next step is winch bumper and bigger tires
That's the same Winch I'm buying.. Bronco is looking good!
FrankBoss
No real updates, other than a broken leaf spring hanger. I guess I'll order a new one from Broncograveyard and do some new shackles.
Still a lil rough with the F150 springs, but better since I removed 2 of the leaves.
Broken! Was it a rusty part? was the carnage so extreme they sent in rescue helicopters!
FrankBoss
Replaced the shackles, and the shackle hanger. Had to put the lift blocks in. It still doesn't sit level.
Played in the mud a bit too
That is buried! Looks like you had fun!
Steve
Meant to call you Steve. This was a place here in Stilly. Bout 80 acres, 2 ponds, plenty of hill climbs and a somewhat easy trail. I got stuck because I went last.
looks good. You have gone the direction I want to go. I want tires and a lift, REAL BAD!!
