country slicker build
kris97ranger
Solid Axle Swap
lisle ontario
Alright a little back story, my gf bought a 94 ranger to dd bit the bed was garbage so she sent me to get a parts truck for her (silly girl.. ill explain later)
Came home with this 97 3.0 stepside for $800 its already on 38.5 boggers
Used to be so clean... lol Probably coulda put fenders and 33s on and ran it as a dd
So i pulled the box and proceeded to wheel this thing all winter
Did some trading and ended up with a tube bed
First real mud run it was open/open and the truck did ok but i cant wheel an unlocked rear so i got home dragged the Lincoln over and proceeded to do what i figured would be a death sentance to the 7.5, hasnt broke yet :icon_thumby:
Went on another local mud run and blew the slave
So then my regular wheeler is having issues so this truck came north for our may 24 trip
Was a good trip nothing broke. Let my gf drive apparently she drives offroad like tim cameron lol
Hard to tell but the front tires are about 2 ft off the ground
Came home with a few dents
Got home sunday ran over to my buddies farm aaand
So i pulled it all apart to replace the shaft and tacked all my u joint caps
And figured seeing as i found a weak link why not make it weaker out came the Lincoln again...
Which worked good until i went to my buddies dads farm
Got wedged between two trees ended up breaking both front shafts and the steering box
And thats where the build begins ill update more later gotta start work now
Oh i more then got my $ worth i think. As of now the whole front clip is cut off and being tubed. I have one bog on the 6th that im gonna run in 3wd then its getting torn down for a sas.
Im waiting on my buddy to pull his 360 outta his 73 f350 (making a fummins) t
en that will be replacing the 3.0
No tons (yet, ask me again after the v8 lol) and yea 4 speed np205. I think i can twin stick that?
As far as I know you can. I think there is a company that makes gears for it too to drop low down to 3:1 instead of 1.97:1. Or you could do a 203/205 doubler.
You may need 1 tons with the 360...
Maybe... we'll see ill cross that bridge when i get to it.
Seeing as im doing nothing at work ill try and add some more here.
This is why i had to ditch the clip. Getting out of a forest with no steering isnt easy
Out came a crappy bender and random pipe ive had forever along with the sawzall
Then it was onto un cluttering what was under the hood. Cut out alot of unessacary plugs that didnt go anywhere and all the wiring for headlights turn signals etc.
Ive got a few things extra id like to ditch as well
Airbag sensor?
Dunno...
Heater relay?
The lower plug on the heater box. The box is smashed so i can see it has a coil in it for what? All i need heat for is winter so i dont need multiple settings, a/c etc
The lower plug is the blower motor resistor for the various fan speeds, the black cube is an air bag crush sensor, the other plug behind the driver headlight is for the ABS module I believe.
Sent from my DROID RAZR using Tapatalk 2
Ok cool so the airbag crush sensor is garbage the abs thing is garbage. And as for the heater can i get rid of it and be stuck with one speed or should i keep it and just run the wires across the firewall?
The black cube was under the drivers headlight. The flat bade thing (abs?) Was under the passenger headlight and the box with the relays was beside the passenger side body mount
You would have to bypass the resistor. I think it would just be a matter of looping the power in to the wire that goes to the motor.
Alright thanks i think im just going to keep it all.
For this airbag sensor can i just trace the wires back to the plug and un pin them or will it set som some safety thing off itd just be the same as unplugging it wouldn't it?.
As for that thing we think is abs i popped the cap off and of the 9 wires going in only two have pins? I dunno what to do with that either
Ok so this used to go to a charcoal canister im assuming thats what it was anyways rectangle plastic box. I pulled it and plugged the line
It goes to the intake so im guessing its vaccum?
Question is can i plug it at the intake and ditch the wiring too?
Got my steering box all swapped out and everything. Then had to pull it back out and put it into my f350....
Got the hood cut down and basic tube work done. Need to get a grill so i can add more in behind it to protect the rad. Also going to add in some 2x4 crossmember that will end up being a hangar for my leaves.
Been stupid busy lately so thats about all ive done to this.
Helped a lady with her car show a few weeks ago had my girlfriend put her 63 mercury in the show and entered my f350 in the show came 3rd in loudest rev contest and tried to compete in my own bog lol turns out 7800lb trucks on bald 35s dont do so good in the mud.
Got home from the show drove to work for a week then blew the sector shaft seal in my steering box put new seal in and blew it again tried that a few times got fed up put a power steering box in and blew that seal. Figured i had a restriction in the lines removed them cleaned it out. Nope no restriction so i put a pump in it.
Same thing blew the seal so i got a 3rd power steering box dropped off while i was at work it was wrong so i had to take half my steering box from my ranger with grooves that wernt rounded out but had all broken internals, and put all my f350 internals into that case. Put it back in and we're good to go!
So i lifted it 4" as a reward. Lol
