- Apr 13, 2008
- Bellefontaine, Ohio
- Automatic
I got bad battery cable corrosion. What causes it? I can clean it but it will build back up. I was gonna replace the battery but I really think it maybe the cable insted it has always seem like the car has had a short or a slight electrical issues it will seem to have a slight electrical studder during start ups. During stops while holding the brakes the car will shake like it just slightly under idle but if I was to put it in park it will stop unless the cooling fan kicks on the it'll shake from that briefly. So it shakes during electrical draws. I thought about just repalcing the battery and both positive and negative cables.
maybe the motor gorund wire is going bad?? Any ideas??
