Black
- Jan 7, 2009
- Automatic
I bought a 93 Ranger 2.3, dirt cheap, not running with a broken timing belt. Replaced the timing belt and also the water pump while I was at it. Fired right up, seemed to run very nicely, but after idling for a few minutes began dumping lots of coolant out the radiator overflow . I'm thinking it's likely a blown head gasket, cracked head, etc, but thought I would check if there is some simple ranger 2.3 quirk I might have overlooked that could also cause this? Don't see any signs of coolant in the oil, so at least I've got that going for me. My compression tester is MIA or I would check that before tearing it all back apart.
