- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Ok about to do some cooling system work on my 99 Ranger.
Since being taken off DD duty a couple years ago it's been neglected a lot more than it deserved. I did yearly oil changes (truck never hit 5K in a year and I was putting in synthetic), checked tire pressure and had the rotated and balanced when due, and that was about it. Never used the truck much so I just forgot about checking stuff. Well I screwed up and let the coolant get too low for a little too long. Found this out when I got about 20 miles down the interstate over the weekend. Noticed the temp gauge starting to creep up so I too quick measures to get the temp back down and limped it home. After truck cooled off I popped the radiator cap and was greeted by a nice orange colored sludge. Really it was a nice looking color, were it not for the fact that it was the color of rust I'd think about painting my next vehicle that color. Unfortunately rust orange is not the color I wanted to see when it should have been neon green.
So right now the plan is to replace the following:
New radiator is not much more expensive than having one cleaned around here especially when you don't trust the shop doing the cleaning, BTDT. Obviously new radiator gets a new cap. The engine has 175K on the clock, so no telling how much of that orange stuff is the water pump fan. Better to replace it while I have the radiator out and easy access. I know the T-stat works, but better to replace it than take a chance of that crud messing it up. Hoses aren't that old, definitely have less than 50K, want to say a lot less than that and appear to be in good condition. If they look rough when I get everything apart I'll reevaluate, but until then I plan to reuse them. I plan to install all the new parts, except the thermostat, so that I have full flow while flushing. Will flush the engine on the hose until it runs clear. Once it flushes clear I'll add engine flush which needs to be run in engine for 6 hours under operating conditions. That's roughly equal to driving to work for a week, so it works out well. Then I'll flush on hose until clear again. Install t-stat, another bottle of engine flush for a week (forgot I already had one on the shelf). Flush on hose again until clear. Test for a couple weeks and then refill with 50/50 mix. Keep a better eye on coolant level.
I know sounds like a lot, I just hope it'll be enough.
On to my questions:
I know I mention a water hose a lot, but when finished it will be drained and filled with distilled and antifreeze or 50/50 premix.
- New radiator
- New radiator cap
- New water pump
- New T-stat
On to my questions:
- Explorer 4.0L SOHC HD radiator is dual core upgrade for Ranger radiator right? If I'm going to buy new might as well upgrade.
- Any recommendations on water pump?
- Does anyone make a water pump gasket that does not require RTV?
- Is there a way to fully drain the block and flush it out with a hose without knocking out a freeze plug? I've heard of some vehicles having a water jacket drain plug, does the 4.0L have one?
