fr7
So I installed a new water pump in the 98 ranger 3.0, while disconnecting the hoses, one of the fittings broke, the store calls it heater tee (Dorman part # 47993), it's the fittings that screws to the block and I believe the temperature switch screws into that fitting and the orange connector plugs into it, then a small hose from there goes to the lower radiator hose.
Anyways, they order one, took 2 days to show up, just to find out the sensor won't screw intothe fitting, even tried a new sensor and it won't fit. They order another one and same thing, sensor won't fit, like the threads are different or something.
The truck has been sitting for a week now and she wants to get out of the garage.
I read you can screw the sensor right to the block and plug the hose. What exactly that sensor/switch do and what will happen if I do that? Is it just for heater purposes or will it mess with anything else?
I'm about to do it but I want to make sure it won't screw something else up. Sorry if I sound dumb but I need to get it done somehow. Thanks guys..
