have this cooling problem, never heard anything like it before. This is my 94 ranger 3.0 splash. Basic rundown on the truck, 125k, motor was out and resealed due to oil leaks, headgaskets were also done. I have put about 3k miles on it since. cooling system was replaces when motor was out, radiator, waterpump, clutch fan, heater core and all hoses. truck runs 185*-190*. Recently had heat issues out of vents due to crap in the cooling system, 100*, now 150*. Here is where the problem lies. Getting a thumping nose out of the cooling system, its not all the time. You can hear it from inside the truck, noise is from under the hood. You can feel the feed hose to the heater core pulse, like it has a heartbeat. Does not do this all the time, engine speed does not seem to effect it, ran it up to 1700rpms and seems to maintain a steady rythem, noise does not increase with engine speed. It the noise accurs and you shut the truck off it continues and slowly fades away. Should be no air in the system, used a no spill kit and had it idle for at least 45mins when refilling it with new antifreeze and distilled water. Had flushed the entire system and ran red devil cooling system cleaner through following their directions. The problem was not there prior to flushing the system. I know its going to be something stupid, just not sure what. Hopefully somebody knows of this problem and knows what it is. truck runs fine, no other issues.
