cooling fan /clutch
rangerpilot
Anyone known of there is a potential issue with swapping my 11 blade cooling fan/clutch combo with a 10 blade version from a similar aged Explorer? I verified it is the same diameter.
My fan blade is quite fatigued and has several crack at the hub. Found a replacement at the junk yard from an Explorer that had a same/similar 4.0 engine.
My only thought was one may be quieter than the other but effective cooling I don't think will be a factor.
