k, about 4 days ago i drained my coolant (replaced the heater core) and then filled it again. I filled the over-flow tank to the "fill cold" line and everthing is fine. Today, i checked my fluid levels and to my wonder and surprise my over-flow tank was empty. Now, the weird thing is that it isn't leaking and it isn't burning (as far as i can tell (by smell)). Now, the rads been replaced witha little bit larger after-market rad and all the hoses are in newly-new condition. The over-flow tank isn't leaking and isn't spilling out the top of the tank. I think i need either a new water-temp sensor (my temp. gauge doesn't work) or a new thermostat (seems more likely that that could be the problem) but i still have no clue where the hell all this coolant is going. When the engine is hot, coolant isn't going into the over-flow and it seems like everyday it takes just a little bit more away from the over-flow until, like today, it's empty. I still have hot air coming through my heater. What i really need to know is: where could all this coolant be going? My heater core isn't leaking because i just just replaced it so... help!
