Oh, two other things because of the age and probability the engine has had a few DIYers working on it
On the throttle linkage, cable side, there maybe a screw adjustment, this is to set minimum idle, not "the idle".
To set it correctly you warm up the engine, then unhook the IAC valve, idle should drop to 500-600rpms, if engine stalls use screw to open throttle a bit more, so it will barely idle at 500-600rpms.
Plug IAC back in and idle should go up to 700-750rpms, might be 800 with an automatic.
Other thing to check are the throttle cables.
Warmed up engine and engine off, open throttle manually and remove both cables, second cable is if it has cruise control.
Now start engine and see if idle is at the normal 750rpm, if so then someone may have done "the throttle cable mod".
Over the years the throttle cable can stretch this makes Full throttle unavailable, so under the dash where the throttle cable attaches to the gas pedal people install zip ties on the cable part to, in effect, "shorten it".
This is fine to do and recommended for better performance, but if done incorrectly you force a high idle but shortening cable too much.
If it has cruise control, leave that cable off and see if idle is normal, if it is then cruise control module maybe pulling the cable a bit when engine is running, it gets it's pulling power from engine vacuum which is highest at idle.
