mdiiorio
Hello I just have a general question.
I have a 1995 Ranger XLT 4 cylinder 2.3l, and I recently replaced the thermostat due to the old one being stuck open and the engine not heating up very fast or blowing hot air properly with the heat on. I also replaced the coolant temp sensor due to accidentally breaking the old one during replacement.
With the new thermostat it is blowing hot air great now and the engine heats up much better, but sometimes the needle goes up above the symbol in the middle of the gauge. It never goes more than 3/4 of the way up the gauge, and when it does go up it never stays there long and always moves back down to the middle pretty quickly, within 10 seconds. Goes up and down pretty predictably while driving and does it much less with the heat on. Drives great, still getting about 25 mpg on every fill up, and no engine codes. Is this movement of the needle normal with this truck?
For the record I changed the coolant and burped it before driving.
Thanks,
Mike
Thanks,
Mike
