Coolant leak
mounties83
Ligonier
Alright i fixed a coolant leak from my thermostat housing about a month ago...the problem was the one bolt's threads were striped so we re-threaded it...before we re-threaded and noticed it was stripped we had put a new thermostat gasket ring in it.....it is now leaking AGAIN....um...just buy another o-ring?...the re-threading worked the bolts are tight...what do you think....sorry about the long read
Are you using any RTV silicone on the mating surfaces of the housing and the lower intake?
