tmcalavy
- Oct 6, 2012
- Automatic
My 93 Ranger XLT with 3.0 seems to suffer from coolant indigestion in the hottest part of the summer. Was checking under the hood yesterday before I left work and noticed that I couldn't see coolant down in the radiator neck. So when I got home I checked the overflow tank...none there and the radiator again after it cooled down. Added 32 oz to the overflow tank, popped the radiator cap and it took about 16-20 oz there so I put the balance in the overflow tank. Started it up, let it run until the stat opened and then shut it off. Most of the year it will show coolant in the radiator when I check, but the overflow won't show any. So what's the best use for the overflow tank...should I use it to top off the radiator...it's too weathered to be able to tell when there's something in there...or should I just keep doing what I'm doing and adding a little to the radiator when it shows to be low a bit when I check stuff under the hood? Nothing but oil on the dipstick and no bubbles in the radiator when it's running and it runs really good considering it's a 21-year-old Ford.
