- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
I was under the impression that coolant went through heater core from thermostat housing to core then to the water pump, Tonight I had switched hoses on the heater core then ran it in case there was a air pocket to be found. I ran it for about 20 min at idle, with my lazer temp scanner tool I observed 130 at the hose connection from the water pump and 95 at the other connection (going to thermostat housing) I noticed by feel that the hoses weren’t the same temperature at the core connections and decided to use my more accurate tool on it. Since its quite a difference in in vs out hose temps (no matter what way it’s supposed to flow) it looks like I need to try a heater core, glad its easy on this and fairly cheap. even though the current core is only about 4 years old, something is not right here.
