monstertruck
I bought this 1994 ranger 4.0 4x4 5-speed. I got it from a friend thats not very mechanically inclined. He said when he bought it the oil was white so he had someone help him replace the heads and all the gaskets, new plugs and wires also. Changed the oil and now the oil is fine, but after a weak or so of driving it let him sit along the road. So I got it for cheap, towed it home put a good battery in it and it started. It seemed to miss really bad so I put new plugs in it, the old ones all looked okay except the gaps wear way to wide. I started it and drove down the road, ran like crap
So I check the firing order and the #5 and6 wires were backward. I switched them drove again seems to be a constant miss on one cylinder, and the converter caught on fire because it started glowing red and was covered in oil, luckely it only burned a vacume line by the time I got it out. I can't find the oil leak it seams to be blowing every where under there. I pull the plugs back out and the front right plug covered in oil. Also the weird part to me is there is white smoke blowing out of the motor at the front right top, near the corner of the intake and head. I cant see exactly where because its behind the a/c pump and bracket, and below the throttlebody. Could it possably be the intake gasket? Or maybe something they did wrong? Any help or suggestions would be great! I do plan on the 5.0 swap but wanted to wait a few months for warmer weather since I don't have a garage to work in.
