Console for 87 Ranger 4X4 Manual Trans??
Killion22
Yamhill, Oregon
Does anyone have any suggestions and/or ideas for a center floor console, to fit around the Manual and 4WD shifter with storage, cupholders, and a place for some switches??:black_eye:
This is what I need fill in, Minus the scanner... I'd like to incorporate that into the console if possible.....
If you make the switch to a bucket seat for the drivers side (bolts to your exsisting track) you can install a Gen2 Bronco2, Gen1 Explorer console.
For mounting switches? I mounted the two switches I needed (Fog and driving lights)
in the trim panel between the headlamp switch and the steering column.
I took the time to make it neat and installed small flush mounted rocker switches.
(I like my knees without divots from impacting switches)
AD
you can convert to buckets and do what Maurice (mjones) did in his Bronco II. Here is a couple pictures:
He also has put 3 in the front of the indicator panel.
i got a 87 to and i like that did you have to wire all that up to??? if so was it a pane in the ass???? what year truck is that and what year did you get the seats and center console from??????
