93splash
I have a 93 ranger splash 2wd with the 4.0. And i want to eventually lower it becasue i love the look. and my friends and I go cruising every Friday night and i am the only stock looking vehicle.
Q1. if i flip the rear hanger that is supposed to give a 2 inch drop on a ranger. the ranger splash leafs have a 1 inch drop built in so wouldn't that be a 3 inch drop in the rear? 2+1=3 right and if i ever do that expo axle swap but kept it a spring under like a flip kit it would be a 5 inch drop right becasue a flip kit is a 4 inch drop plus my drop leafs is 1 so 4+1=5 inch right???????? I am so confused. Hopefully someone will help me. thanks a lot.
Q2. The wheels i have are the same ones as on this mustang
http://scofieldpros.com/db2/00112/scofieldpros.com/_uimages/2001FordMustangOct08.JPG
and has anybody ever seen them used on a ranger? I herd that i need 5/16 wheel spacers to run the front center caps on the wheels. If that's true would i need to get longer wheel studs or will my stock ones be fine. Thanks.
thanks so much Rusty p.s. I did search but didn't find anything
