Confused About Rear Leaves
Franklin, NC
Ok so I was gonna replace my rear springs in my Ranger, a 94 ex cab 4x4. The back sags pretty bad, more on the drivers side which I understand is typical. I started researching and can only find 4 and 5 leaf springs. Mine are only 3 and don't look like anythings broken. They look alot like the explorer springs but if that's the case I think mine were put on backwards. The little clip around the leaves is at the back not the front like every picture I can find. So I need to figure out what springs I need to replace mine. I've got coil spacers in front so I wanna keep the same height rear, except for the sag ha. If anybody can help me figure this out it'd be great cause without trial and error I'm not sure how to go about it.
The springs can't go on backwards (well, not without the axle ending up about 6" further to the rear).
I'm not sure what all is available for replacement springs, but if they're listed as a stock replacement spring, i would think they should be within a half-inch of what the original height was when the truck was new (which is likely higher than it is now if your current springs have sagged at all).
If needed, you can always adjust the height some with different shackles or a different size block in place of the stock one.
The xlt you has weaker leaves than what you are looking at ordering they around the same height my buddy has the 3 pack on his xlt and I have the 5 pack on my edge height is the same
