If they have the same trans (IE both manual) the chances are high, but '94 was the first year for a couple things that would cause problems, the '93 won't have a cam sensor the '94 "might" (cam sensor is on the oil pump drive around where the PCV valve is, just behind the power steering bracket if equipped), and I believe '94 was the first year for the DPFE sensor for the EGR flow. I believe both of those changes were for California trucks not 49 state... Other than those two things, should be direct swap
For
