cckc135r
So I completed the compression test and here is what I got.
1. 150
2. 145
3. 150
4. 150
5. 95
6. 150
This was cranking pressure clutch disengaged and throttle wide open and engine cold. I guess nexy i'll head down to the parts store to get a cooling system pressure tester. I also pulled the radiator out. Cooling fins were clogged with dirt so I washed all the nastys out and ran clean water through the radiator. It was dirty but nothing chunky. So I'm looking opinions on the 95psi cylinder. Here's what I'm thinking of doing along with pressure checking. Pulling valve cover off to make sure the rockers are adjusted right too. forgot to mention that t
he spark plug was good and showed no signs of a head gasket. So offer up what you think gentleman and ladies. Thanks in advance for your thoughts.
1. 150
2. 145
3. 150
4. 150
5. 95
6. 150
