It appears that this truck does not have an EGR or DPFE. Is the PCV in the 90 degree hose that runs from the back of the intake to the valve cover on the drivers side?
I assume you replace it as an assembly.
THanks
The IAC if its in the same place as my 94 which i be it is on the driver side, about half way back and if i remember right the highest thing off the ground. Mine had a plastic cover over it and the throttle. It has 2 bolts holding it down. Google it and you should be able to find some pics so you know just what it looks like.
For
