compleckz's ranger build
updated first post with about a dozen new pics, still not caught up.
i also started adding further down, the stuff i am currently working on, that way i dont get further behind.
5/31/08
Awesome X2.
I'm totally stealing that idea, props to your GF.
the paint is so she can see the drive shaft next time right ?
by the way the truck is looking awesome cant wait to see what else you have in mind for it.
i love the truck, and this build thread is very useful for me, one question i have for you tho, when you origionally did the lift did you lower the 2 piece driveshaft carrier bearing or was it ok as stock?
you are gunna start going through u-joints. i need to lower the carrier bearing or go with a 98 + drive line. every 5- 6 months i throw the middle joint in the shaft.
yea definitely 98 + i just am trying to get it lifted and then worry about buying the shaft, i am just wondering if he had to lower his immediatly or not, did you have to or is that why your throwing joints?
lol, exactly!
when you originally did the lift did you lower the 2 piece driveshaft carrier bearing or was it ok as stock?
well the truck only had about 90k when i lifted it, and i think i drove another 10k or so on the 2-piece stock shaft. it did vibrate quite a bit up until about 25mph, but i never had any problems/joint failures.
i finally replaced it with my first 98+ shaft, to eliminate the vibration and prevent the failures that were sure to happen eventually. although, the skyjacker 6" kit isn't a true 6" lift (or wasn't on my extended cab), so if you actually have 6" of lift--the wear would be accelerated on the joints, and the vibration would be worse.
cliff notes: no i didnt lower the carrier bearing, i drove about 10k miles (daily driver) before installing the 1-piece shaft.
thanks for all the comments guys! currently the truck is being 'lowered' for state safety inspection. will get pics tomorrow!
UPDATED FIRST POST! added my 8" coil and 6" leaf swaps, explorer 8.8 rear swap... lockright, powertrax no slip.. all old stuff.. no new progress on truck
lol, exactly!
thanks bro, i appreciate the reply. keep the pics coming, this is one of the only builds i am 100% interested in!
back from the dead aka page 11!
i decided to add some recent breaks and fixes.. nothing really new.. and the first page isn't up to date with where the truck is now..
all new ball joints + steering, drive shaft u-joints,
skyjacker nitro's up front, to match the rear (2" longer, replacing awful skyjacker hydros)
relocated/extended front hard brake lines ((again) giving about 3" more slack in the flexible lines)
unbent, non-cracked: drivers TTBeam
repaired/reinforced drivers radius arm
freshly painted: coil springs, radius arms, brackets, random hardware
here are the latest pics:
this happened on a ranger meet here in western mass, in october, broken upper rad arm tab:
plan to fix
cracked beam
stripped new beam:
cleaned up:
this is how we do:
stripping bent and cracked beam:
diff yoke bolts:
bend:
crack:
front diff, gears, locker--all still mint.
repaired and painted arm.
pretty!
got it all fixed.. and everything was fine for a few weeks.. then i broke: every single shaft in the front end again.... i let the truck sit for months, school and my gti project took over..
then i finally got around to putting in a fresh set of shafts, brand new 760x's tacked.. all fixed.
testing...
next day:
and this:
today i did this:
then i was able to drive out..
and then i did this 100feet ahead:
sad face:
so i gave up for the day (this area is on my property).. then the next day i dug out, and
ended up busting the right hub too..
new hubz
other side, oops, i guess i twisted the shaft, and it took out... everything. i was really hoping it was just the hub.
got that ish out 3wd:
