Coming Soon
MastuhWaffles
11/2014 OTOTM Winner
OTOTM Winner
TRS Banner 2012-2015
Texas
I need more sleep.
Doing the Explorer 8.8 swap, this is a 3.73 with the factory posi.
Picked it up for $200.
Not bad. Make sure you pick up the leaf spring perches rather than cut and weld the perches, this gives you a jacking pad to lift the vehicle...
SVT
Yes, next week I'm coming back home to clean it up, paint it, get everything wired up and the brackets welded on so it will be ready for the swap when I get a week off. So I was thinking about painting it yellow.
This weekend I'm cleaning it up, painting it yellow, welding on new mounts, and fixing brakes.
Today I got to work on the brakes, I'm waiting for some parking brake shoes, I've got everything else ready, and I've taken most of the stuff off, like the shock and the sway bar. I'll get some pics.
FYI, the Explorers had bolt on shock mounts that work really well. It would save you from welding tabs onto the axle. SVT mentioned them above.
10649732_708608865877827_7244290982613204181_n_zpsa6239a46.jpg~original
10628061_708608899211157_1376635540617424852_n_zps710d487a.jpg~original
10620534_708608879211159_5724492823261234400_n_zps7a4d3626.jpg~original
10592827_708145152590865_2612481510338777516_n_zpsbe5305f1.jpg~original
10626641_708608925877821_6278334688965182752_n_zpsea11e1b1.jpg~original
I got some work done. Just need to put on the new diff cover, clean it up, paint it, and put on the new mounts.
Alright next week I plan to do the swap, so I'll post some pictures.
So, we didn't have the welding equipment an unfortunately there were no places around that were open to do the welding so it will have to wait till monday to be welded up. I put my older axle back in with my truck but replaced the old broken shocks with new Rancho RS5000s like the front.
Getting it ready.
DONE
Have to adjust the parking brake and check the speedo and we are good.
Nice! Looks good
AJ
sent from a galaxy near me
Looks like you lifted the rear - right? What did you set the pinion angle to? Did you lift the front as well?
