D Lenz
Hello ... Having some difficulties putting a 2.8L back together. Have a reground crank and the bearings supplied came with a 2 part thrust bearing. This block needs a 6 piece thrust bearing. The journal for the the 6 piece is just about .050" too narrow to fit the 2 piece (ie slop). Is there a supplier for shims to make up the difference or should I just go ahead and find 6 piece bearing set, or make my own shims?
Thanks
Thanks
