- Jul 15, 2020
- central Texas
- 4.0 V6
- Automatic
- Total Lift
- 2"
- Tire Size
- 235/75r15
And pickles......
Well of course its flat. You've just reached the edge where it's cold because that's farthest from the sun.
Can you tell where the oil came from?
That’s a possibility I will have to check out. So basically if it freezes, blow by pushes oil through the seals right? When I got home I pulled the crankcase vent line off and didn’t feel much air there. None through the fill hole in the valve cover either. I just hope I caught it early enough to not do terrible damage to the engine.
Check the PCV valve on the Ranger, it may have moisture in it that froze and caused a pressure build up.
If you need to escape the cold you can all come hang out in my basement. It's very warm down there. There's also plenty of soup and its not even a dangerous pit of despair from which you will never escape or anything. Nope just a nice warm haven of soup and happy fun times.
Yes. There's a lot of pressure in there. The PCV valve relieves that pressure by blowing it into the intake (right?). If the pressure builds up too much, then.....
BANG!!
With the PCV valve restricted pressure would build up and push oil/oil vapor out. Old engines had vents on top and a road draft tube hanging down underneath. As the vehicle moved down the road, air rushing by the tube generated the draft and pulled the vapors out. That's why the roads used to have a dark strip down the middle of the lanes and motorcycles knew not to ride in the center but to stay in the wheel tracks.
You said you just changed the oil... maybe your new filter popped at the seam... filter didn't get tight and seal leaking... oil pressure switch let go...
Yes... the double gasket could be a possibility too.
I give the OP benefit of doubt that he wiped the filter sealing surface clean before installing the new filter.
29 and raining, not good for the trees.
