Rollin
- Oct 1, 2009
- Automatic
Hello,
Ok, the colder out it gets the longer cranking it takes for it to start. The other morning it was about 30 deg. out and it must of turned over 20 times before it would start up. Soon as it fires up it runs great, runs about 1200rpm for about a min. then drops to about 800rpm and purrs like a cat. It starts right up when the motor is warm or its not cold out.
There are no codes , I have replaced the ect sensor, gaped plugs , new upper intake gaskets, new fuel filter, no vacuum leaks, cleaned the Maf sensor, ran sea foam in it.
Now I did replace the throttle body with one from a 95 motor and they looked the same except 95 has two small air holes on butterfly valve--the 90 only had one hole. But I think it was still hard starting then too.
I noticed on the side of upper intake manifold there is a sensor there what does it tell the computer what to do. Like I said the motor throws no codes and runs great after its started up and warm, or its not cold out.
I am not sure what to try next. I do have a fuel pressure regulator from the 95 motor , can I throw that on and see if it help or is it different pressure from the 90.
Thanks
Thanks
