brianvonlehe
- Jan 16, 2009
Hi everyone-
New to the Ranger thing, have already learned a lot reading here and working on my truck.
I picked up an 89 2.3 5spd 2wd ranger for 300 bucks this fall, 140,000 miles, and have been tuning it up a bit. I did all the fluids and filters (except fuel filter) and am now replacing the radiator hoses, thermostat, timing belt, spark plugs, plug wires, and PCV valve. So I've got the alternator and radiator fan off and the engine is pretty accessible, so i thought it would be a good time to check on something:
The truck starts good and runs reliably at 21/25 mpg (with snow tires, sand, and 10% ethanol), and other than the muffler being blown out (up next), and a slow tranny leak, the only weird thing is a relatively loud banging noise, in rhythm with the engine rpm, which although it's too fast to count, seems to happen once each engine revolution. This noise always dissapears once the engine is warm (within 5 minutes), and never happened until the weather got cold. A mechanic friend suggested that it may be a valve not seating and that there wasn't anything that i should do about it. I haven't checked to see if the noise goes away at the same time the thermostat opens but i think it goes away much before that.
What do you think?
Thanks a bunch
Brian
What do you think?
Thanks a bunch
Brian
