Coil spring spacers and leveling coils?
rangeron31s
Grafton, WV
Hey, I have a 96 ranger 4x4 , and I was gonna put the leveling coils on it, but i was on ebay and seen were the had a 2inch lift kit that comes with coil spring spacers and lift blocks and u bolts and shock extensions. My question is has anybody used both of these together, or if you can do that?
No it cant be done you will run into some serious alignment problems. I sugest saveing up and buying a James Duff 3inch lift kit.
Agreed, you can only go up about 2" before you need axle brackets to drop the axle down. Spacers + coils is likely to take you way above that.
