Labguy
I was hoping someone might have some insight or suggestions about a possible issue I'm chasing on my 2003 Ranger XLT 3.0L automatic. I'm not the original owner of this truck and the guy I bought it from did not install the lift parts on it, and knew very little about the suspension.
Here's what I have. The truck is currently riding on 31" Toyo's, and I have completely rebuild the front suspension with all new components except the 3" Fabtech lift spindles and the coil springs (manufacturer unknown, but dimensions appear stock).
The problems I'm chasing are a nose high look on the truck and a very rough ride. I thought after I rebuild the suspension it would level off, but it never did. The front suspension was shot and every joint was wasted, it needed it. When I did the front suspension I also installed some lift shackles in the rear to try and counteract the nose high condition, but it didn't help. The rough ride was there when I bought the truck, it just wandered more before the front end rebuild. It rides like a tank.
My question is, is there anyway to know if I'm dealing with stock springs or some sort of lift spring. I know the spindles are Fabtech parts because of the part numbers. I currently have the spring out of the drivers side and on the bench. I replaced the old Monroe shocks with a set of KYB basic truck shocks for the application.
I have also heard these trucks can ride rough, but am I just going to have to deal with it or is there a fix I can try?
I'm mainly trying to get this truck straightened out for daily driving duties, with maybe the occasional trip on back roads in northern Michigan.
Any suggestions?
Thank you,
Alan (Labguy)
Any suggestions?
Thank you,
Alan (Labguy)
