Coil Spacer Questions. PLEASE HELP
Shawn_248
Lexington SC
I found on ebay some coil spacers. Some are made of polyeurathane like the daystars, and some made of billet aluminum. I'm gona probably get the metal ones bc they seem more durable, but my q is can I pair the spacers with some leveling coils to get more lift? And would I have to do any other mods to make this work? Sorry if I sound dumb
do you plan on having the truck drive normal after ya stack two leveling systems on it? if ya go over 2" of lift you gotta change the drop brackets for the TTB...
so yes, you'd have to mod the drop brackets for the two beams and the radius arms. and then the front end would be sitting higher than the back if ya don't lift the back too... AND you could just buy some washers and tuck under the coil mount on the bottom to get your truck leveled too, that'd be cheaper than both of those leveling "kit" things.
