popman
- Jan 5, 2010
- Automatic
2001 ranger edge 3.0 4wd .
I had a heater valve burst which I replaced but during the activity of the leak it seemed I noticed it was running rough. I fixed the leaky valve which is directly above the coil pack where coolant ran all over it. I suspected a bad or wet plug wire and pulled them off one at a time to check for spark and found one port was not sending out any spark. I switched wires with another plug to eliminate it being a plug wire and the sam port same problem. It looks clean inside of the port and as added measure I blew it out with a compressor to make sure it was dry. So are those packs sealed? If so would that be the problem by coincidence? Fyi, I recently replaced the cam sensor without issue.
Thanks in advance!
Thanks in advance!
