manger
here's what I got so far from a 2000 Ford Mustang Workshop Manual:
code 1131 see possible causes for code 1130
Possible causes:
Elecrical
1. short to VPWR in harness or HO2S.
2. water in harness connector.
3. open shorted HO2S circuit
4. corrosion or poor mating terminals and wiring
5. damaged HO2S
6. damaged PCM
Fuel System
1. excessive fuel pressure
2. leaking contaminated fuel injectors
3. leaking fuel pressure regulator
4. low fuel pressure or running out of fuel
5. vapor recovery system
Induction System
1. Air leaks after MAF
2. Vacuum leaks
3. PCV system
4. improperly seated engine oil dip stick
EGR System
1. Leaking gasket
2. stuck EGR Valve
3. Leaking diaphram or EVR
Base Engine
1. oil overfilled
2. cam timing
3. cylinder compression
4. exaust leaks before or near the HO2S.
I'll be back with my progress! God Bless Your RBV!
Possible causes:
Elecrical
5. damaged HO2S
6. damaged PCM
Fuel System
Induction System
2. Vacuum leaks
3. PCV system
EGR System
1. Leaking gasket
2. stuck EGR Valve
Base Engine
1. oil overfilled
2. cam timing
