Code: 172 (EGO?)
The Gat
Alaska
1976
1994 Ranger 108k or 208k or 308k miles... The previous owner claimed it is at 108k. The CEL goes off and on when the motor is stressed. If I floor it, it doesn't go any faster but seems to lose speed but runs at 3000-3250 RPMs. I checked the catalytic converters today and they are not plugged.
So, I had a buddy next door run the codes and it pulled 172 and was running lean on bank 2 (I think bank 2) and something about cylinder 1. He said to check the MAF and so I did, it was clean and looked brand new. He said something about an EGO but we were not sure what this is. Also, he said I may need to replace my O2 sensors.
I have not yet done anything to it but changed the spark plugs, wires and welded a flowmaster on. I'm currently running 328 miles to a near empty tank.
I ended up replacing the o2 sensors and nothing happened. In the post "MAF required?" I found out that he had a similar problem so I unplugged my MAF while it is running and it now runs like a FORD should. Can I keep this unplugged or is that bad for the motor?
