madmax401
- Aug 7, 2007
code 14 pip keeps popping up on me on my 88 f250 5.8 fi. every one else had similar problems with their 2.9 and replace all components. i too have replaced everything = new MSD pro billet distributor and then another brand new pro billet distributor. runs for a little while smoothly but not no real power when you step into the pedal. pull the codes again and 14 comes back after it was cleared prior to the re test. if 14 is erratic PIP signal and ive replaced the tfi module and distrbutor with brand new ones......where else could my problem be.could my ECM be defective? does my ECM have anything to do with PIP? I HAVE SPARK TO THE PLUGS * I HAVE 40LBS CONSTANT FUEL PRESSURE AT THE RAIL*NEW FPR* BOTH FUEL PUMPS KICK ON AND RUN* ive read in another post that somebodys truck would run ok down the street and the horrible on the way back. mine , when running is smooth idle and lacks top end power.........after i shut it down and try to re start........it wont start . totally baffeling . my guess is to replace everything from where PIP start starts all the way up to the 6 pin tfi distributor module plug. spark and fuel are present at all times ! does anyone have a link that will show the PIP wiring circuit ?
