Ryannn
I have replaced everything that involves starting the 4.0 in my 90 Ranger, cables, plugs, solenoid on the firewall, icm, coil pack, battery, battery cables. Pretty much everything is brandnew and I still pull the pip 14 code and only that code. Some times it fires right up others it cranks over excessively. Any other suggestions, ive spent about 700$ replacing everything......
Also how hard is it to replace the RABS module behind the ash tray? and can I take one from an explorer/b2/ranger of any year? Also would the RABS module cause my spedo not to work, because when the brakes drag the spedo jumps around...
Thanks Ryan
Thanks Ryan
