clutch
stocker
ok the other day my clutch went soft and i checked the fulid level it was almost empty so i added some and then tryed bleeding it but it wont bleed what do u guy think happened i think i might of blown the pressure plate
How do you "blow" a pressure plate?
If you lost fluid, it went somewhere. Probably out the slave, but inspect for other leaks.
+1, it probly is the slave. Check for leaks.
your slave cyl is bad i would replace both the cyl and the lines that go to it
lol bein stuiped i did a power brake bout 30 foot and then the clutch went soft
well i think it was a seal not the plate but how hard a is a slave cylinder 2 put in
It's not necessary (and rather expensive) to replace the line. Only do so if it is damaged or leaking.
It's only available from the dealer and comes with a master cylinder attached.
