- Dec 14, 2008
- Lacey, Washington
- Manual
Replaced slave and master with new. flywheel is new. bleed system over 2 different days. Forced fluid up to master cylinder through slave. Clutch fork moves when pedal is pressed. Adjusted freeplay on master push rod and backed of 1/4 turn. Clutch still will not engage cannot shift gears with vehicle running. I if transfer is in neutral trans can be shifted. Been working on this over 2 weeks. Does any one have a miracle cure.
