clutch trouble
legacy man
My clutch doesn't want to disengage and the petal is soft.
I did bleed it in the truck and the fluid was almost black.
Line leak or blown seal...
Or at least an improper bleed. You might as well do a complete clutch job...
The lines are good and its not leaking anywhere, also the part by the pressureplate does move about half to three quarters of an inch.
Check the firewall for broken/cracks/rust around the mc bolts. Re-bleed. Pedal softness is air in the lines or a leak.
Honestly i dont know the order the clutch parts goin in, but if the plate separates then it's disengaged...
I found that when i changed my clutch, i had to remove the master from the firewall and turn it to an angle that allows any air bubble to bleed up and out. even after a good gravity bleed air was getting stuck up by the pedal. after that worked like a champ, oh and hose clamps, they really help a hydraulic system perform too. (i forgot them and fixed em before finding air problem)
