Therigwelder
My 93 ranger’s clutch appears to be slipping however I cannot find a reason why. Initially I thought there may be oil leaking on the clutch. After pulling the clutch out I found nothing, everything looks good. could it be a weak pressure plate?The clutch setup was replaced 6 months ago. The transmission shifts fine through all the gears, good clutch pedal.driving around town I have no problems, after driving for awhile on the interstate i begins to slip first in fifth gear then Throughout the gear range the longer it is driven and while going up inclines. Is there anything that can mimic a slipping clutch
