clutch slave/master issues?
BWOLIVER
Keyport, WA
just put a new slave in for the clutch bled , bled, and bled again. It still doesn't engage( truck moves while cranking with clutch pedal depressed) don't have alot of clutch/tranny experience. HELP the only reason the slave was replaced was that when the kid put in a new clutch stripped a slave bolt and didn't let me know and the push rod shot out driving down the road(had to power shift home) what the heck am I doing wrong?
Once the master is full of air it has to be removed and positioned with the hose end up hill so the air can escape. once you reposition the master it will bleed itself when you open the bleeder. Make sure you don't let the resevoir go dry or you will have to start over.
John
got it, thanks all. bleed bleed and more bleed. I guess thats the secret.
