- Aug 11, 2007
- Age
- 70
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
To bypass switch splice together the White/pink stripe wire with Pink wire
This is the correct wires...they should be the lower two wires on the connector...and there should be six wires on the CSS.
There is also a pin or nub that fits into the end of the longer part that is attached to the fixed part on the shaft...that nub fits into the hole and holds the part with the wires in place...from the pictures you showed in your first post, it looks like you are missing the shaft with the nub on the end...that is why it keeps sliding.
I would just bypass the two wires for now to test the starting circuit....you can tape it into place sort of permanently if you can't find the nub to hold it in place (junkyard item)...
I drove my first Ranger like that for almost 15 years...never had an issue with anything in all that time...except for when the U shaped wire fell out once due to a poor taping job.
As for why we even have a CSS...if you've driven a manual transmission for even a month or so you will never forget to either put the truck in neutral when starting or depress the clutch...I never used neutral unless I was doing work on the motor and had to go back and forth to start or turn the key and didn't want to climb in each time...
