You are a dope.
You can't put a 10 inch clutch on a 2.8/2.9 flywheel. The new clutch is 10 inches across, the old one only 8 2/3. That makes the old flywheel at most 9.5 inches across. There is no way to get a 4.0 clutch and pressure plate bolted to a 2.9 flywheel.
You need, from a 91-97 Ranger/Explorer 4.0L:
flywheel
clutch kit
starter for a manual trans (they are different)
a new 60" 4 gauge battery cable
a roll of 10-12 gauge wire
Tow packs of eyelets: One set big enough to fit over your starter relay post, one big enough to fit over your starter solenoid trigger post.
The trigger post is the one with the wire that says "do not remove". Its easier to make your own wire and take that one off than to splice/crimp your new wire onto that one.
