steviep
- Apr 25, 2008
I have a 98 4x4 with a 3.0 with 5 speed . When I press on the clutch pedel it seems very weak. I have to start my truck in gear and when I do it seems to lunge foward a little. After getting truck up to speed it will shift but it is still a little on the hard side. The resivore is full and when taking off the rubber inspection cover I can see what I believe to be the slave cylinder disengage the clutch about a half inch. Is there a way to test the master or slave cylinder. The truck doesn't seem to have the normal worn out symtoms like engine over reving while climbing hills. Also the pedal doesn't seem to disengage the clutch until it is almost bottomed out. I am trying not to remove transmission, as the clutch is less than 15000 miles and 3 years old.
